My Dell is leaky and I can't make it stop, Please Help |
cdmcse |
Jun 30 2005, 10:30 PM
Member Group: Members Posts: 340 Joined: 17-December 04 From: Georgetown, Ky Member No.: 3,305 |
I have Dellorto 40s on my car (1.8L). During my rustoration over the winter I went ahead and rebuilt them and re-jetted them. The driver side works perfectly, but the passenger side has what I am assuming to be a float problem.
When the gas flows to the carb it just gushes out both throats and I can't figure out why. I have had the carb apart 6 or 7 times now, but can't make it better. Here are the things I've done already... 1)Tried every combination of old and new needle and seat. (The carbs never had this problem prior to the re-build) 2) Adjusted the float - I can blow in the inlet and with light pressure on the float it seems to stop ok. 3) Checked all the gaskets / seals 4) Tested the float, it floats like a cork 5) Ran my fuel pressure down to 1psi (normally it is a 4psi) 6) Inspected everything and saw no debris or dirt anywhere. (they were cleaned in a parts washer during the re-build) 7) Once it is assembled I can hear the float moving freely in the body. Any other suggestions. What could it be? I'm stumped. |
cdmcse |
Jul 2 2005, 11:34 PM
Sweet, I'll see if that guy can help me out. Now where do you adjust the float level at? The small flat piece that pushes the needle, or the one closer to the screw hole? |
Lo-Fi Version | Time is now: 18th June 2024 - 08:00 AM |
