brer |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None ![]() |
Put the rocker assemblies back on my heads and drove home to san diego.
got very loud rocker noises coming from the engine re adjust the valves. drive it for a little while and bigger clacking noise and starting to lose power. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) I think i *effed* it up installing the new studs and then torqing the rocker assembly nuts with my old torque wrench. thought i seated the studs properly, and torqued the nuts right, but now the valves dont seem to be holding an adjust. so what the worst that could have happened? stripped the studs from the heads right? |
Type 4 Unleashed |
CREATIVE TYPE lV ENGINEERING ![]() ![]() ![]() Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None ![]() |
Sorry, for the scare, it's not a flat cam, it's something simple. You, may not have gotten the push rods, all the way in the lifters when you put it back together, then after you ran it they poped into place, then left alot of clearance, and would make alot of noise. Then, the PO may not of spent the money to have the heads rebuit right. Should have at very least had the exhaust valves replaced, probally didn't, new springs would of also been a good idea. Then there's the quality of the work done by the shop, they may not of even refaced the tips of the valves, the stok rockers are setup to rotate the valves, and that cleans up the seat and valve face, but also concave's the valve tips, and when you adjust the valves, to the proper clearance, there is still the wear in the valve tip that you can't adjust out, and so will always be noisey. Then there's the retainer keepers, there just so much, and alot of people do QUICK CHEAP fixes, especially if there selling the car. Keep this post updated, with what you find out, plenty of people here to help you out, I'am not the only one here with an opinion with whats wrong. |
Lo-Fi Version | Time is now: 25th June 2024 - 12:11 AM |
