> Ignition problem
1bad914
post Jul 6 2005, 08:05 AM
Trying to help a friend with his 74 Carbed 1.8. The car ran last year, he just pulled it out for the summer and the fuel pump was not running, but the car turned over. He asked me to give him a hand, the end result is he is not getting power to the coil (fuel pump is wired to the + side of the coil), checked fuses and relays and can find no problem. When you turn the ignition switch to ACC the idiot lights are not coming on and no power to the coil, continue to turn the ignition switch and the car turns over, but still no power to coil. Any suggestions??
Thanks,
Mueller
post Jul 6 2005, 09:25 AM
914 Freak!
here you go, get out your Volt Meter....
this is from Lapuwali's Blog (James M.)
Excellent Blog
14 pin
1 yellow, main trunk, starter wire from ignition switch
2 blue, main trunk, goes to G light on combo gauge
3 gray/brown, main trunk, switched +12, attached at brake switch
4 gray/brown, below engine harness, reversing lamp
5 green/red, main trunk, oil pressure light
6 green/black, main trunk, oil temp gauge (even if not fitted, may not be on '72 -)
7 black/purple, main trunk, tach signal wire
8 black, main trunk, switched +12 from fuse 8
9 green/white, main trunk, rear blower switch
10 brown, grounding point for main power relay
11 brown/white, main trunk, "optional for sportomatic"
12 red, battery + terminal, to main power relay
13 black/red, to fuel pump (+12, switched by FP relay)
14 red, from battery +, to 25A fuse on board, FP relay and others
12 pin
1 green/red, engine harness, oil pressure switch
2 gray/brown, below engine, reversing switch
3 green/black, below engine, oil temp sender (might only be on '70-'71)
4 gray/brown, below engine, reversing switch
5 black/purple, engine harness, coil - (tach signal)
6 yellow, starter solenoid
7 black/red, coil +, ignition power
8 N/C
9 N/C
10 N/C
11 green, blower motor
12 white, Aux Air Regulator (AAR)
- Lo-Fi Version Time is now: 27th December 2024 - 12:07 AM
