groot |
Dis member ![]() ![]() ![]() Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 ![]() |
I have no idea what camshaft this is, so I was hoping somebody could identify it for me.
I measured the lift to be between .283 and .289" at each lobe. There's a ridge that goes 1/2 way around the cam just before the second bearing. Here's a pic... |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
yep, run .035- You need all the compression you can get.
BTW- have you been data logging EGT? If so I'd like to see what you had EGT wise with the old combo to see if you were running it slightly retarded with the high octane. This way I may be able to crunch some numbers and start you out at a better base line for timing advance this time.. |
Lo-Fi Version | Time is now: 25th June 2024 - 09:59 PM |
