jfort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,137 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest ![]() ![]() |
Jim Chambers kindly forwarded the followiing instructions for changing the headlight switch wiring so that the headlights stay down until the second stop:
Question: How do you rewire headlight circuit so lights stay down on first "click" (parking lights) of switch? Disconnect battery ground strap. Remove two screws, allowing fuse panel to drop, and unscrew bezel allowing headlight switch to be pulled out from rear so terminals are visible (leave all connected). Terminal "K" on the switch has 3 gray wires attached. One is a jumper to terminal 58b. Remove the smaller (diameter) of the other two gray wires from "K" and attach it to terminal 56 of switch (has re/white lead on it). Reconnect battery, give switch a try, and if all OK, disconnect battery again, replace switch and fuse panel, reconnect battery final time. I tried it. One of the "other two gray wires" has two wires coming into the same terminal so I am not sure which is the smaller one. I can try it both ways. Then, does the smaller of the other two gray wires on K go to terminal 56 IN ADDITION to the red/white wire already on 56, or IN PLACE OF IT?? If the former, I'll need to find one of those connectors that allows TWO female connectors onto the same male terminal. If the latter, what happens to the red/white wire? Can anybody help?? |
garyh |
Member ![]() ![]() Group: Members Posts: 170 Joined: 8-January 03 From: San Mateo, CA Member No.: 114 ![]() |
QUOTE(jfort @ Jul 22 2003, 06:08 AM) Question: How do you rewire headlight circuit so lights stay down on first "click" (parking lights) of switch? I don't understand the question. From the factory, if you PULL to the 1st click, the parking lights are on, headlights are off, and DOWN. If you PUSH to the 1st click, parking lights are on, headlights are off, and UP. (You have to go to the 2nd click to push to the 1st click.) Perhaps the answer is to remove some DPO disease? |
Lo-Fi Version | Time is now: 24th June 2024 - 11:21 PM |
