Strange Electrical Problem, everything kinda works. |
YksKrad |
Jul 14 2005, 11:06 AM
Member Group: Members Posts: 72 Joined: 14-February 05 From: Rolla, MO Member No.: 3,602 Region Association: Upper MidWest |
Okay this is very strange to me.
My battery completely drained about a week ago because I left my running lights on in the garage and didn't come back for 4 days from camping. Now the strange part. I used this as a reason to by an Orbital battery, and when I tried to turn on my 914 I didn't get that delightfull hum of my electric fuel pump and my starter did nothing. okay so now I'm pissed because electrical anything isn't my strong point. Last time I have to do wireing of anything I ended up with a burnt thumb. So I decide to see what else is working/not working. I flip my left blinker on. The signal comes on but doesn't blink.... I do the same with the right with the same result... it comes on but doesn't blink. I try the hazzrds and they do the same thing. I turn the radio on. It's face lights come on and the speakers crackel as it gets power, but it doesn't play music? I try my lights... The running lights come on, but my headlights won't come up. I scanned my fuses and didn't see any missing/burnt Though I should prolley check again. This pisses me off because I just got the damn thing running like a top (a slightly rich top, but a top non the less) and then this happens, and once again the thing is sitting in the garage. More info on the car. It's a 76 with a 2.0 converted from FI to a single weber carb with an electric fuel pump. Any help/sympathy is appreciated. I am by no means a mechanic and have no clue where to start looking for the problem(s) let allone fixing them. Once again thank you all |
YksKrad |
Jul 15 2005, 08:19 AM
Thank you, I'll try that, but I don't think thats the problem when cupled with the other problems that popped up simulataneusly and that mine use to blink regardless.
Which makes me wonder if someone did a (bad) rewire job on it. Which would explain why my flasher relay and it's wires were found in a pile under the passenger seat, and why when I first got it the Stereo was drawing the power off the hazzard switch. Either way I'm checking the battery wires for wear and possible shorts and I'll check all the connections I can get to easily like you suggested today. I'll post with the results when I get them. |
Lo-Fi Version | Time is now: 31st October 2024 - 10:26 PM |
