Problem with Rennshift hitting floor |
hars914 |
Jul 16 2005, 05:56 PM
Member Group: Members Posts: 114 Joined: 6-January 03 Member No.: 94 |
I was installing my new Rennshift shifter today and ran into a problem.I adjusted
the shifter for the 30% throw and when I went to install it I noticed the clevis was hitting the floor pan and prevented the shifter from sitting flush on the tunnel. Has anyone had this problem?? Will I have to fab a spacer similar to the Weltmeister kit? I installed it with the 20% throw and it fit fine. It also was a real bitch getting the shifting right. I would get 1 thru 4 fine but it was not going into 5th.When I got it into 5th It would not go into 3rd. I finally got a happy medium and plan on test driving tommorow.Any thoughts on adjusting the pattern? |
Brad Roberts |
Jul 16 2005, 07:46 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Guy's.. it doesnt take much to dent the tub from the bottom. Take a small block of wood and push the pan back down. I would imagine this is the problem. The biggest issue I have seen with the shifter... some of them hit the clutch tube (if it was improperly repaired after breaking in the past) The bottom will swing out when you go for 4th gear and hit the clutch tube if the tube is not in its proper place.
B |
Lo-Fi Version | Time is now: 24th June 2024 - 11:37 PM |
