DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
What is the rim width on these wheels? Or did they come in various widths?
Thanks (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) |
DanT |
Yesssss!!!
Will probably run in GGR Class BI or BP depending on how I finally set it up. since it is a virgin with suspension...I will see what I can come up with. This will be my 3rd 4 banger 914 and I want to try some different things. I may go to BP even though the motor will be stock.... I want to use big gun drilled front torsion bars, large front sway, Konis etc., 180# rears, with threaded shock body. And then get it corner balanced, and as low as possible, with max neg camber. Looking forward to a light AX car again. |
Lo-Fi Version | Time is now: 25th June 2024 - 12:24 AM |
