110v Welder Q, extension cords? |
tat2dphreak |
Jul 17 2005, 02:02 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
my garage isn't exactly built to weld in (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) the only plug is in the ceiling and the cord to the welder doesn't reach... what extension cords are Safe to use with a welder? I don't want to blow a breaker, I don't even know where the fuse box is, and I don't think the apartments would take it too kindly...
914GT |
Jul 17 2005, 05:15 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
If there's a duplex outlet on the end of the extension cord where the welder is plugged in, stick the leads of an AC voltmeter into the spare outlet. Otherwise you'll have to touch the leads to the prongs right where it's plugged in. If the voltage never dips below 105V or so while welding you are OK (assumes your line voltage normally about 120V). If it drops below 100 then your welder may give you some problems. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:23 AM |
