Name this part, Reassembled trans with part left over |
tmh75 |
Jul 16 2005, 07:22 PM
Member Group: Members Posts: 74 Joined: 25-January 05 From: bozeman, mt Member No.: 3,506 |
I'm in the (long and drawn out) process of rebuilding my 1.7 to a 2056. I've been waiting on parts forever and have lost lots of motivation. Now I'm finally getting things back together.
Transmission: Took apart to replace syncros, probably 3 months ago. Just got it back together today. One problem, theres a small wavey washer under the tranny when I'm done. Could be from anything, but was under tranny Any ideas?? Also, Put compression bolt (big one under speedo drive gear) back on with impact wrench, was unable to use a torque wrench. I'm sure that it is above 80 foot lbs. Anyone heard of any probs with this being Over torque? Thanks in advance Todd Attached image(s) |
jhadler |
Jul 18 2005, 02:43 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Yup, Brad was spot on. As soon as I saw that little washer I said "YOU!!! You @#$#%!!!"....
Man, that little washer was my nemsis last year. Was getting the motor ready for an Electromtive ignition and electric fan conversion. Was almost there, and just needed to pul the dizz and cap off the hole. The oiling washer stuck to the distributor until it was -almost- out of the motor... plink.. plunk... cluck... LIttle bugger dropped down under the cam gear, and nothing I did would get it out of there. Had the motor on the engine stand and was spinning it over, shaking it, thwacking it with a big rubber mallet. Nothing. It was in there good. So... 12 months later, and nearly a full rebuild (once you're in there right.... (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) ), I'm almost back to where I was... -Josh2 |
Lo-Fi Version | Time is now: 26th September 2024 - 11:51 AM |
