> 914 V8 or Pantera Detomaso, WHich would your prefer
Jaiden
post Jul 22 2005, 10:14 AM
Guys,
I found an unrestored 1974 Pantera Detomaso GTS that one of my fiance's bridesmaids has stashed away in the family Garage. The Car does not currently run (stored for 14 years) and I could probably get it (if I can gather the money) for a VERY good price.
Which would you guys go for the Pantera or a 914 V8?
bondo
post Jul 22 2005, 03:50 PM
QUOTE (phantom914 @ Jul 22 2005, 02:29 PM)
QUOTE (LongARM @ Jul 22 2005, 01:26 PM)
Pantrera for  sure....
check out the engine area in this 74..
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
Interesting. The CV joints look like U-Joints.
Andrew
I *think* the way they do it is u-joints at each end of the shaft, but the shaft is actually a splined shaft inside a splined tube. One joint is attached to the shaft, the other to the tube. This allows the length change needed for suspension travel. I don't know the advantages/disadvantages of it vs. CV joints.
Jaiden   914 V8 or Pantera Detomaso   Jul 22 2005, 10:14 AM
Aaron Cox   pantera.....   Jul 22 2005, 10:16 AM
VegasRacer   easy question - PANTERA   Jul 22 2005, 10:18 AM
tat2dphreak   http://ww...   Jul 22 2005, 10:24 AM
ArtechnikA   the stuff of sci-fi movies for years. Godzilla va...   Jul 22 2005, 10:26 AM
TimT   Pantera   Jul 22 2005, 10:28 AM
bondo   Both! (Duh!) http://www.914...   Jul 22 2005, 10:31 AM
jimkelly   A Pantera of course - put a 1.7L and tailshifter i...   Jul 22 2005, 10:31 AM
Travis Neff   P P P P P Panterrra   Jul 22 2005, 10:33 AM
Jaiden   Man you guys are quick! Yeah I pretty much th...   Jul 22 2005, 10:38 AM
andys   Before deciding to build a 914 V8, I looked real h...   Jul 22 2005, 10:44 AM
Cap'n Krusty   RUST! Look for it in the shock towers, as I r...   Jul 22 2005, 10:49 AM
RON S.   http://www.914world.com/bbs2/h...   Jul 22 2005, 10:50 AM
tod914   No brainer... Pantera. The engine rebuild on that...   Jul 22 2005, 11:43 AM
dmenche914   I like the Pantera. Other car is the early Lotus ...   Jul 22 2005, 11:44 AM
neo914-6   Use the Pantera ZF in a V8 914 and dump the rest, ...   Jul 22 2005, 11:50 AM
Ferg   Ahhh, my fantasy car http:/...   Jul 22 2005, 11:52 AM
Lou W   Pantera http://www.914world.com/bbs...   Jul 22 2005, 11:59 AM
tat2dphreak   I'd give my left nut for a pantera, how's ...   Jul 22 2005, 12:05 PM
grantsfo   Pantera by a wide margin. They have a big showing...   Jul 22 2005, 12:08 PM
redshift   =\ Damn! You just missed my Pantera rant...   Jul 22 2005, 12:11 PM
Ferg   ...   Jul 22 2005, 12:15 PM
tyler   914 V8 all the way (which I have now). I bought a ...   Jul 22 2005, 12:41 PM
scruz914   Pantera! Screw the driving position and comfo...   Jul 22 2005, 01:02 PM
Andyrew   Pantera can hold the hp and tq much better than th...   Jul 22 2005, 01:07 PM
tat2dphreak   IIRC, the engine is just a FORD(351 IIRC)... not t...   Jul 22 2005, 01:08 PM
Eddie Williams     Jul 22 2005, 03:07 PM
Dr. Roger   Thank you Ben, I was just going to say that. =-))...   Jul 22 2005, 03:07 PM
bondo   The windsor is a small block, the cleavland is a b...   Jul 22 2005, 03:11 PM
tat2dphreak     Jul 22 2005, 03:19 PM
lapuwali   There is or was a Pantera only shop in Mountain Vi...   Jul 22 2005, 03:20 PM
tat2dphreak   if nothing else, you can buy the car, and if you d...   Jul 22 2005, 03:24 PM
LongARM   Pantrera for sure.... check out the engine area i...   Jul 22 2005, 03:26 PM
phantom914   <...   Jul 22 2005, 03:29 PM
redshift   Is it ok if we use this thread to roast Panteras? ...   Jul 22 2005, 03:31 PM
phantom914   ...   Jul 22 2005, 03:35 PM
neo914-6   Pantera rant: A well known automotive designer / i...   Jul 22 2005, 03:42 PM
Headrage   Will the tranny fit in a teener?   Jul 22 2005, 03:45 PM
redshift   http://www.914world.com/bbs2/html/e...   Jul 22 2005, 03:46 PM
Headrage   Hmmm?   Jul 22 2005, 03:49 PM
bondo   ...   Jul 22 2005, 03:51 PM
bondo   ...   Jul 22 2005, 03:52 PM
Headrage   ...   Jul 22 2005, 03:54 PM
redshift   I think I saw it somwhere that Bruce sent me a cou...   Jul 22 2005, 04:29 PM
neo914-6   ...   Jul 22 2005, 04:37 PM
redshift   Yeah, new is not expensive, or cheap, depending on...   Jul 22 2005, 04:54 PM
jd74914   Panteras are nice. A friend of mine's uncle to...   Jul 22 2005, 06:39 PM
LS6/914   Worked late 70s early 80s at a shop that serviced ...   Jul 22 2005, 09:14 PM
9144guy   i worked on this 73' last month   Jul 22 2005, 09:24 PM
9144guy   guess that pic. was cut short , another   Jul 22 2005, 09:28 PM
- Lo-Fi Version Time is now: 6th January 2025 - 03:07 PM
