> I'm never going to finish, more bad luck
tat2dphreak
post Jul 22 2005, 08:11 PM
stoya, stoya, stoya
I mated the tranny and the engine back tonight... mind you I only seperated them like 3 weeks ago, when they were seperated, everything fit fine...
now, 1 out of the 2 studs on the bottom seems too short (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) WTF?!
the tranny seems flush with the engine, but the stud is only BARELY poking through the hole, not out far enough to even get a bolt on(even with no washer)! a washer BARELY fits...
here's a pic... what the hell?!
Joseph Mills
post Jul 24 2005, 10:11 PM
on a Sonoma diet now...
QUOTE (jr91472 @ Jul 24 2005, 09:11 PM)
QUOTE (jr91472 @ Jul 24 2005, 04:36 PM)
I am thinking no.  But don't listen to me, I have had to pull my tranny about 6 times in the last year.  Number 7 is tonite in another attempt to solve my leaking rear main seal.
later
JR
(IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif)
Ha!!!! I am a dumbass..... (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
Just got done pulling the tranny (1hr 30min....thankyou, thankyou).
After all my ranting about a leaky rear main seal, it turns out that it was the tranny seal for the input shaft......
I guess I need some smellier gear oil, cuz I failed the sniff test.....bad.
oh well.
That tranny seal can be tough. Use a piece of lead pipe a bit smaller than the outer edge of the face of the seal to gently and slowly tap it into place. Stop every few taps and observe it to verify it's moving evenly. Sometimes just before they are "seated" flush, they will tend to flange out on you. If that happens, discard it and try another one.
If your shaft is worn at the seal spot, you can unscrew the spring inside the seal, snip off a bit and twist it back together to produce a tighter grip.
We used some adhesive on the outer surface of my last seal. Doesn't seem to leak a bit. I forget what we used, but can look it up for you if you like. PM me.
Good luck with it and hope to see you at the MUSR7
tat2dphreak   I'm never going to finish   Jul 22 2005, 08:11 PM
tat2dphreak   http://www.914world.com/bbs2/h...   Jul 22 2005, 08:11 PM
Headrage   Show a pic where the tranny and engine meet.   Jul 22 2005, 08:13 PM
spare time toys   Something holding the trans back?   Jul 22 2005, 08:14 PM
SirAndy   ...   Jul 22 2005, 08:14 PM
bondo   It's your avatar that's causing the troubl...   Jul 22 2005, 08:15 PM
echocanyons   Did you take off the clutch? If so did you align i...   Jul 22 2005, 08:27 PM
Aaron Cox   obviously something is holding the trans up....   Jul 22 2005, 08:30 PM
rhodyguy   christ. that fuckers filthy. k   Jul 22 2005, 10:43 PM
redshift   I'll bet you dirty grease has hardened up in...   Jul 22 2005, 10:45 PM
tat2dphreak   yes, the tranny is a dirty mother fucker... I...   Jul 23 2005, 07:26 AM
jr91472   http://www.914world.com/bbs2/...   Jul 23 2005, 10:38 AM
tat2dphreak   http://www.914world.com/bbs2/htm...   Jul 23 2005, 10:39 AM
tat2dphreak   http://www.914world.com/bbs2/html/e...   Jul 23 2005, 10:40 AM
tat2dphreak   http://www.914world.com/bbs2/h...   Jul 23 2005, 10:41 AM
SpecialK   Something VERY strange going on here. ...   Jul 23 2005, 07:11 PM
tat2dphreak   ...   Jul 24 2005, 07:46 AM
tat2dphreak   I compared my stud length on this engine to the co...   Jul 24 2005, 06:09 PM
jr91472   <...   Jul 24 2005, 06:47 PM
tat2dphreak   <...   Jul 24 2005, 09:11 PM
tat2dphreak   <...   Jul 24 2005, 09:32 PM
Joseph Mills   <...   Jul 24 2005, 10:11 PM
- Lo-Fi Version Time is now: 6th January 2025 - 07:51 PM
