> Hoosier AS04 thoughts and impressions, i just corded a set...
nebreitling
post Jul 27 2005, 04:58 PM
Member Emeritus
because i know a lot of you guys are running them right now, below are my thoughts and impressions. YMMV
i snagged a set of these up at the beginning of the year at closeout pricing -- something like $118/tire -- and have run them at AX since. although these tires would normally be out of my budget (183/tire), i couldn't pass up this deal.
these were mounted on my street-mod car, app 1900#s w/out driver weight, pretty hot cammed/carbed 2056cc ~115 rwhp, 205/50 on 15x6.5" wheels. they are wider than a typical 205, but pulling fenders is part of the fun.
first off, they are obviously a fairly major competitive advantage. although the new kumho 710s appear to be just as fast (and wear better, at that), i'd estimate that the hoosiers were worth .5 to 1 sec over victoracers or yoko A032's, all things being equal.
WEAR
they were competitive for 6 events. at my 7th event, they went off, showed cords, and were just generally unpredictable and quite less grippy, although they turned in and transitioned just about as well as they did when fresh. honestly, i'm surprised they gripped as well as they did for having cords showing! you can drive them hard up to the end!
do the math, though. after shipping and mounting these things, i had a little over $600 in them. at ~60 minutes of life, that's $10 per minute. ie each run you take costs you $10. clearly, you don't drive these on the street.
RUNNING THEM IN
if i were to buy these again, i'd have them heat cycled to try to get them faster out of the box -- and to try to extract more life out of them. definitely: you want to run them in as hoosier suggests -- heating them up slowly and them dismounting them and letting them rest for a few days.
my tires were not as fast my first event as they were my 2nd, 3rd, etc. my 4th and 5th events, they were at their peak. or maybe i had just figured out how to drive them (more later).
TIRE PRESSURES
When i first got these, Randal told me to run 'em low. Hoosier recommends 40+psi for these tires on a light weight car.
Randal is right.
i ran my hoosier AS04's low (against factory suggestions) -- they had more mechanical grip, but didn't set turns or transition as quickly. they also gave slightly poorer feedback and were trickier to control at the limit compared to more 'reasonable' pressures. but this resulted in undeniably quicker times, and would hook up in a fast sweeper like a slot car.
i found that 26-28 psi was a nice trade-off, although randal mentioned to go as low as 24. at my 7th event, i ran them between 23-25 just to try to get some good rubber in the contact patch -- not just corded rubber. felt *different*, but certainly gave me better grip in the fast sweepers.
CAMBER
i run lots -- particularly up front. more than any other 914 in my class in my region.
while most of the older books i've read say to adjust camber until you reach an evenly distributed tire temp, hoosier suggests to run neg camber sufficient to heat up the inside more than the outside. while this will wear them more quickly, they'll perform better.
even given my alignment settings, the tires wore quite evenly across their width. despite these settings, and despite a liberal use of power-induced wheel-spin (which will heat up and wear the inside edges of the Rear tires), i still corded the outer edges -- not the inner. this is probably an indication of the effects of AX on tires more than alignment settings or drivers' style, but still says something to me.
a caution, however: you can go too far with neg camber -- particularly in the rear....
TIRE BEHAVIOR
these tires turn in and transition like a motherfucker. you can ATTACK slaloms. absolutely phenomenal -- and loads of fun!
while they have excellent latitudinal grip, they have LESS than ideal longitudinal grip IMHO. easy to spin, easy to lock up during braking. little warning, also, so it takes some experience to know where the braking threshold is.
they DO NOT like a high slip angle. keep it well under 10%, for sure! (do some measurements on how far the wheel needs to be turned to get your front tires to turn 5%, 10%, 15%, etc., and you'll start to gain a feel for quantifying slip angle. you need to do measure this stuff anyway to check castor settings.).
because of their phenomenal turn-in, it's easy to gain a false sense of confidence with their ability to keep up with your input. you HAVE to drive tidy with low slip angles! if anything, these tires were worth a $600 investment JUST to teach me about how to drive a given slip-angle.
again, these are just my subjective impressions -- YMMV -- but i hope there are a few points in here to help some of you guys kick ass on these tires! please feel free to debate, reiterate, or disagree with this.
nathan
nebreitling
post Jul 27 2005, 07:00 PM
Member Emeritus
QUOTE (rhodyguy @ Jul 27 2005, 04:39 PM)
expensive hobby. wish i had your kind of cash (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) HA! that's the best! i'm a grad student -- i take a salary from stanford for my research and teaching, but i'm clearly out under budgeted for this dumb sport... hell, my car is built 90% out of used parts and other people's spares. BUT, i can live cheap, and i have an understanding girlfriend (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) you'd laugh if you saw my budget. it's like 40% car...
so, new skins or street tires for the rest of the season?
good question. i don't know. if i can scrape up the $$, i'll spring for a set of 710s -- but circumstances require me to put my cash elsewhere for the next few months. i've got some very tired victoracers, but i'm saving those to tear up at the track next week. also have some VERY crusty hoosier RS03's, but i wanted to save those for DE as well...
might just run my street tires for a while. although i'll miss being competitive, my driving could use a lot of refinement. i want to spend time focusing not necessarily on winning, but on reading the course -- and then hitting every single damn apex on every single damn run i take.
nebreitling   Hoosier AS04 thoughts and impressions   Jul 27 2005, 04:58 PM
nebreitling   pic   Jul 27 2005, 04:59 PM
nebreitling   pic   Jul 27 2005, 05:00 PM
J P Stein   The obivious question is ....how much is "more cam...   Jul 27 2005, 05:24 PM
nebreitling   i think their wear pattern was a result of the low...   Jul 27 2005, 05:28 PM
J P Stein   I will admit the comparison is a bit of apples/ora...   Jul 27 2005, 05:42 PM
ottox914   I too grabbed some of the "close out" SO4's, a...   Jul 27 2005, 06:30 PM
trekkor   I am going to re-mount mine inside out after the n...   Jul 27 2005, 06:35 PM
rhodyguy   exspensive hobby. wish i had your kind of cash   Jul 27 2005, 06:39 PM
SirAndy   i run my R250 goodyears at 17 and 19 lbs ... i mig...   Jul 27 2005, 06:48 PM
Randal     Jul 27 2005, 06:50 PM
ppickerell   Nathan, Do you run those on stock wheels with no f...   Jul 27 2005, 06:58 PM
nebreitling   ...   Jul 27 2005, 07:00 PM
nebreitling     Jul 27 2005, 07:08 PM
Randal   Are there any of the cheap last years Hoosiers sti...   Jul 27 2005, 07:09 PM
nebreitling   someone said that tirerack had 'em -- but i co...   Jul 27 2005, 07:12 PM
Randal
trekkor   I just checked R&S Racing, where I got mine and th...   Jul 27 2005, 07:21 PM
trekkor   I'm going out on a limb...don't saw it off...   Jul 27 2005, 07:31 PM
nebreitling   high rev-ing /6 no torque   Jul 27 2005, 07:46 PM
grantsfo   Just some very subjective observations from my van...   Jul 27 2005, 07:48 PM
nebreitling     Jul 27 2005, 07:51 PM
xitspd   Nathan, The Hoosier AS04's are worth a minimu...   Jul 27 2005, 07:58 PM
nebreitling   ...   Jul 27 2005, 07:59 PM
KenH   Nathan, I found my Kumhos wearing as your tires e...   Jul 27 2005, 08:05 PM
trekkor
  Jul 27 2005, 08:19 PM
nebreitling   i didn't mean it as a slight at all, trekkor. ...   Jul 27 2005, 08:41 PM
trekkor   I know you weren't diggin' on me. Just the...   Jul 27 2005, 08:51 PM
grantsfo   Toyo RA1s are going for around $120 but they ...   Jul 27 2005, 09:35 PM
nebreitling   ha! yeah, albert better get himself an alignm...   Jul 27 2005, 10:46 PM
grantsfo   ...   Jul 28 2005, 10:36 AM
grantsfo   Has anyone tried the Hankook DOT AX slick (Ventus ...   Jul 28 2005, 10:58 AM
rhodyguy   i guess i'll need to pointedly ask someone to ...   Jul 28 2005, 10:58 AM
nebreitling   <...   Jul 28 2005, 11:14 AM
trekkor
  Jul 28 2005, 11:19 AM
trekkor
  Jul 28 2005, 11:31 AM
grantsfo   <...   Jul 28 2005, 05:36 PM
- Lo-Fi Version Time is now: 31st October 2024 - 07:31 PM
