> Idle problems, I know you know!!!
BahnBrenner914
post Jul 27 2005, 10:00 PM
The girl is gone and all I have now is a beat-up teener
From: Gig Harbor and University Place, WA :: School in Angola, IN :: girlfriend in Sarasota, FL
So the ongoing project has been restarted after a 3 month break... no comment... and i fired the car up again and it starts and runs and isnt hunting much... the problem is that it idles at 1500 when i fire it up and then it slowly (really SLOWLY, like 30 seconds) climbs up to 2000 and i dont know if it will climb higher (i'll post a comment when i let it run longer tonight). I know 99% of you all have dealt with this, so help me go from (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) to (IMG:http://www.914world.com/bbs2/html/emoticons/driving-girl.gif)
Bleyseng
post Jul 27 2005, 11:10 PM
Aircooled Baby!
check to make sure the vacuum hoses are connected correctly and check for vacuum leaks.
If the AAR valve is working it will start out with a 1500-1800 idle then after 5 minutes drop down to whatever you idle is set to.
To check to vacuum leaks plug the AAR valve hose so it can't leak and then you can look for other leaks.
BahnBrenner914   Idle problems   Jul 27 2005, 10:00 PM
Bleyseng   check to make sure the vacuum hoses are connected ...   Jul 27 2005, 11:10 PM
Rand   Mine also idles faster after warmed up, and it...   Jul 27 2005, 11:49 PM
Dave_Darling   The AAR typically fails open, though I have heard ...   Jul 28 2005, 12:39 AM
Rand   Ok, good to know. But in my particular case, the ...   Jul 28 2005, 12:52 AM
Bleyseng   I vote this is the number one complaint, bad idle....   Jul 28 2005, 07:28 AM
BahnBrenner914   yeah, i started it up last night and it started ru...   Jul 28 2005, 12:28 PM
Bleyseng   see pic   Jul 28 2005, 02:20 PM
smooth_eddy   The AAR is easy to remove and bench test with alig...   Jul 28 2005, 04:30 PM
redshift   ...   Jul 28 2005, 04:36 PM
Bleyseng   here is how Miles fixes his AAR valve...by doing t...   Jul 28 2005, 04:48 PM
Dave_Darling   Also check the Decel Valve. It could be sticking ...   Jul 28 2005, 05:52 PM
DNHunt   Damn Miles that's one tall sheep.   Jul 28 2005, 06:31 PM
fatlando   my car is doing the same up and down thing too. I...   Jul 28 2005, 07:49 PM
BahnBrenner914
- Lo-Fi Version Time is now: 27th December 2024 - 01:32 PM
