TIV Cylinder Head Gaskets, what is the official story???? |
John |
Jul 28 2005, 09:44 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I am having some leakage problems with a 2.0 4-cyl and I am trying to narrow down where the leak is coming from.
I thought it was an exhaust leak, but have changed heat exchangers, had the new exchanger off several times and Can not seem to see any evidence of the exhaust leak at the copper exhaust gaskets. None of the exhaust studs are loose or pulled. I even went to the extent of changing cylinder heads, but the leak remains. When I changed cylinder heads, I did not know of any information regarding the elimination of the cylinder head gaskets, so I believe that I have them installed. How likely is it that the cylinder head gaskets can be the source of a leak? My exhaust leak is intermittent when the engine is up to temperature. (It is quiet while it is warming up idling, but after it is warmed up, sometimes at idle you can notice what sounds like a slight exhaust leak. Not real loud, but noticable) I was thinking that it may be a cracked cylinder (near the mating surface of the head), but the more I have read about the elimination of the cylinder head gaskets, the more I think that the leak could be those aluminum gaskets. Does anyone have any information with regards to a bulletin released concerning the elimination of these cylinder head gaskets, and could I get a copy? I would greatly appreciate some advice on this matter. Thanks. |
John |
Jul 28 2005, 10:13 PM
I originally re-assembled the engine in the early 90's. I swapped cylinder heads in 95 or 96 when I noticed the noise for the first time.
I haven't driven the car much over the years, but wanted to get it on the road this summer. I tried re-sealing the heat exhcngers this spring, but could find no evidence of leakage there. My exhaust leakage persists. The car runs strong and idles well. I would drive it more if I could solve the leakage issue. Anyone have info on the service bulletin??????? |
Lo-Fi Version | Time is now: 23rd June 2024 - 12:21 PM |
