> Brakes, Stopping with M, A, or S
johnmhudson111
post Jul 28 2005, 08:11 AM
Coupe of questions about brakes. First of all what is the difference between "M", "A", and "S" capliers? Is it the mounting bolt distance? Early vs.Late? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Did the 914/6 come with "M" capliers? If not what did they come with? Can these brakes be upgraded to something like the "big reds?
DanT
post Aug 1 2005, 03:42 PM
Going back to the Dark Side!
Eric,
Your quote:
"I'll have a 200-220hp -6 in my GT with S-Calipers up front and 911 M-Calipers in the rear (T-Fitting). I'm using the 911 handbrake assembly. Same basic setup that came on a 76 930 (with 240hp and a similar 7 & 8 x 15 wheel/tire package) "
So how did you get the 911 M calipers to fit on the rear? Will those fit on the rear with your modified 5 bolt control arms?
IF so are those M front Calipers or match M rears?
In my conversion I am not concerned about an "E" brake so I am just looking for a good fade resistant system for the track that will stop well and not require bleeding after every 30 minute session.
Years ago I had a 914-6 with a 2.7L RS motor and had JFZ 4 pistion calipers front and rear. The bias was always too much to the rear.
I want to avoid this problem this time around.
So what would be your preference among these choices?
M calipers front and 914 rears with ebrake.
M calipers front and 914 front calipers on the rear with no Ebrake.
A calipers on the front with M calipers on the rear with no ebrake
SC complete front and rear with no ebrake.
Complete Carrera fronts and rears with no ebrake.
What type of adapters or whatever would be required to make these work with the modified 5 bolt control arms.
I just want to do this one time.
I contacted Rich and he seems to think the SC calipers will just bolt right on to your control arm ears with 3 inch spacing.
Thanks
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
johnmhudson111   Brakes   Jul 28 2005, 08:11 AM
ClayPerrine   M caliper. Cast iron 2 piston caliper. Uses 3" b...   Jul 28 2005, 08:27 AM
johnmhudson111     Jul 28 2005, 12:20 PM
Eric_Shea   Ahhhhhhhhhhhh Hello, Clay... S-Calipers arrived a...   Jul 28 2005, 08:40 PM
johnmhudson111     Jul 31 2005, 09:34 AM
Series9   Here's too much brake on a 914. They work GRE...   Jul 31 2005, 11:49 AM
Oled   Mike, Good to hear from you. I started off with ...   Jul 31 2005, 03:42 PM
Oled   Total piston area on various calipers M, S, A Fr...   Jul 31 2005, 04:02 PM
Eric_Shea   Joe, That's a "HUGE" brake line. Do you use ...   Jul 31 2005, 04:39 PM
Eric_Shea   And I know what you guys are thinking, after looki...   Jul 31 2005, 04:52 PM
Dan (Almaden Valley)     Aug 1 2005, 11:52 AM
Porsche Rescue   Had my coffee. Here's what I see so far. Front...   Aug 1 2005, 12:27 PM
rdauenhauer   Is the machining of the R. stock -4 piston bores o...   Aug 1 2005, 12:42 PM
Eric_Shea   We discussed (Mike Mueller and others in a previou...   Aug 1 2005, 01:32 PM
Porsche Rescue   Here is a front caliper on my conversion car. Anyo...   Aug 1 2005, 01:33 PM
Porsche Rescue   and the right side   Aug 1 2005, 01:34 PM
Porsche Rescue   How about stock 4 caliper with one nipple? As you ...   Aug 1 2005, 01:39 PM
Eric_Shea   Jim, those are M-Calipers. Early w/o the spacer. ...   Aug 1 2005, 08:02 PM
Porsche Rescue   Eric, they must be 914-4 calipers. I recall that e...   Aug 1 2005, 08:23 PM
Eric_Shea   Early 4's had one bleeder and Ribe head throug...   Aug 1 2005, 08:32 PM
Porsche Rescue   Well, what do I have?   Aug 1 2005, 08:37 PM
Eric_Shea   Early -4 from looking at the bolts and bleeder and...   Aug 1 2005, 08:49 PM
Porsche Rescue   That's the car. Doubt it would have anything t...   Aug 1 2005, 09:10 PM
Porsche Rescue   Answered my own question. Looked at PET and learne...   Aug 1 2005, 09:25 PM
Dan (Almaden Valley)   Eric, What is a "V-caliper" you refer to for the r...   Aug 1 2005, 10:14 PM
ArtechnikA   ...   Aug 2 2005, 08:05 AM
Eric_Shea   Danke Rich! http://www.9...   Aug 2 2005, 09:53 AM
Root_Werks   This is a good thread full of info. I like the re...   Aug 2 2005, 09:59 AM
Porsche Rescue   Eric, if late '72 (transition) were "one nippl...   Aug 2 2005, 10:09 AM
Eric_Shea
  Aug 2 2005, 01:47 PM
Eric_Shea   Jim, That's what I was thinking too. There...   Aug 2 2005, 01:49 PM
ArtechnikA   ...   Aug 2 2005, 01:56 PM
Eric_Shea   So the 914 is a "medium" motor car... we knew that...   Aug 2 2005, 02:28 PM
Eddie914   What are the dimensions of Carrera rotors? Are th...   Aug 2 2005, 05:25 PM
johnmhudson111     Aug 2 2005, 07:11 PM
ArtechnikA   it is the application of the service brake that ke...   Aug 2 2005, 07:52 PM
Eric_Shea
  Aug 3 2005, 10:24 PM
johnmhudson111     Aug 4 2005, 05:13 PM
ein 6er   here is a link to the mechanism.   Aug 4 2005, 06:36 PM
Eric_Shea   Those look "fairly" easy to mfg. Any of you machi...   Aug 7 2005, 02:45 PM
- Lo-Fi Version Time is now: 26th June 2024 - 12:23 PM
