SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,711 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
so on my way to the AX saturday i noticed a "clunk" sound from the frontend, like i had lost something.
i had this happen before, bolt came lose on the swaybar droplink, so i thought that was it ... when i get to the AX site and change tires, i see the droplink hanging all weird so i take a closer look and the lower hime joint has broken. the thread just snapped off the joint. i then continue to change the tire on the other side and it's exactly the same! (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) both hime joints broke in the exact same location. that seems too odd to be coincidence. i must have hit something *really* hard for that to happen, but i can't remember running over any bad potholes etc. anyone else had problems before? (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) Andy |
Demick |
Ernie made me do it! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 ![]() ![]() |
Another consideration is that the lower heim joint range is not the issue - it could be the upper heim joint. I'm going just by pictures here, but the way that the upper joint is mounted it looks like the big washer severely restricts the amount of side to side motion of the drop link. If the top one binds (under decompression when the A-arm is extended which pulls the lower mounting point inboard), it will try to bend the drop link, and that could cause the bottom joint to fail.
Demick |
Lo-Fi Version | Time is now: 28th June 2024 - 03:35 PM |
