Valve adjustment question? Help!, Strange valve covers with vents? |
Jaiden |
Aug 6 2005, 08:24 PM
Member Group: Members Posts: 346 Joined: 13-January 05 From: Stroudsburg PA Member No.: 3,443 |
hey all,
Well I decided to take a look at the valves but removing the valve covers is proving to be a pain. I have a '75 2.0l in my '72 914. The valve covers are bolt on finned aluminum with metal vents on the top that pass through the engine tin and stick theough about 1.25 inches. The vents hook into the oil fill breather. I could not get the cover off without removing this vent. The problem is that the vent is through mounted on the valve cover and there is no way to put the vents back in? I thought the vents were supposed to face the tranny and come through the engine tin past the valve cover. The covers have holes that face that way but are threaded holes plugged with screws. It does not look like anything the directions show. Also after getting the covers off my valve adjustment locking nuts need at 14mm not a 13mm what gives? Any thoughts |
SGB |
Aug 8 2005, 12:03 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
I plugged those vents with a stub of hose and some brass stock. I didn't hose-clamp 'em on, and did have some oil get pushed past the slip on connection point. Its true that the heads are at equal pressure as the crankcase 'cause of the PR tubes I guess, but I think you can get some short term pressure differentials from oil sloshing back & forth in the case, into the PR tubes, etc, during turns.
I removed my block off peices and put in a bug-pack oil breather thing on the back firewall. I think if you block the vents it will increase the potential for valve cover gasket leaks. just my 2 million pesos. |
Lo-Fi Version | Time is now: 6th January 2025 - 05:21 PM |
