Ball Joint, Replacement Questions |
johnmhudson111 |
Aug 15 2005, 01:52 PM
Member Group: Members Posts: 491 Joined: 29-November 04 From: Nesbit, MS Member No.: 3,191 |
So I am wacking away on the pickle fork seperating the 914 strut from the a arm and I notice I have effectivly destroyed the ball joints rubber cover and grease (I assume) is everywhere. I am thinking, this isn't good. No problem I got another set on the 911 a-arms, happy times again, but wait a second it turns out there is a special tool that you have to have to unscrew the nut on the bottom of the ball joint. Pelican has them for around $50. So that leads me to my two questions:
1. is there another way to remove the ball joint nut? if not is there a cheaper source? 2. is it unwise to use a used ball joint? Don't mind buying new but hey if you ain't got to.... (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
John2kx |
Aug 15 2005, 03:43 PM
Senior Member Group: Members Posts: 502 Joined: 22-August 03 From: Augusta, Ga. Member No.: 1,066 |
John,
I bought the "special tool" and still could not get enough grip on nut before tool slipped. Ended up using a pipe wrench and could not believe how easy it was. As cheap as ball joints are, I would not replace with a used piece. Just my opinion. John Attached image(s) |
Lo-Fi Version | Time is now: 26th June 2024 - 09:14 AM |
