johnmhudson111 |
Member ![]() ![]() Group: Members Posts: 491 Joined: 29-November 04 From: Nesbit, MS Member No.: 3,191 ![]() |
So I am wacking away on the pickle fork seperating the 914 strut from the a arm and I notice I have effectivly destroyed the ball joints rubber cover and grease (I assume) is everywhere. I am thinking, this isn't good. No problem I got another set on the 911 a-arms, happy times again, but wait a second it turns out there is a special tool that you have to have to unscrew the nut on the bottom of the ball joint. Pelican has them for around $50. So that leads me to my two questions:
1. is there another way to remove the ball joint nut? if not is there a cheaper source? 2. is it unwise to use a used ball joint? Don't mind buying new but hey if you ain't got to.... (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
i thought you have a big fancy compressor? a hammer and a pipe wrench and distroy an a-arm, nice (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif). what do you use for penetrating fluid caveman? the combo of penetrant and the rapid vibrations of the pneumatic help break the rust bond.
k |
Lo-Fi Version | Time is now: 26th June 2024 - 09:18 AM |
