SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
this was supposed to be a simple stripped down BASE64 decoder done in java.
i don't (can't) use a lot of standard libraries because this App will be run on PDAs and java enabled cellphones, so SIZE does matter. no problem, i get one of my contractors the BASE64 specs and some sample implementations ... he's been fighting with this for 3 days now so i get his sourcefile and have a look at it this morning. looks OK at first glance, but when you run it, it sporadically spits out wrong bytevalues while some decode just fine. wtf? so i spend all day going through his code (which is not that much) and i just can't figure out what's wrong. then finally, about 15 minutes ago it dawns on me, have a look at this: bReturn2[nn+2] = (byte)(iRes % 0xFF); bReturn2[nn+1] = (byte)((iRes >> 8) % 0xFF); bReturn2[nn+0] = (byte)((iRes >> 16) % 0xFF); bReturn2 is a byte array, iRes a integer, the purpose is to roll the lower 3 bytes of the integer into 3 sequential fields in the byte array. i had been staring at this for 6 hours and couldn't figure out what was wrong. all the while it was right in front of me, plain sight, right there ... (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) can you find the error? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Andy PS: did i mention that i HATE going through someone else code? |
SpecialK |
aircraft surgeon ![]() ![]() ![]() ![]() Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 ![]() ![]() |
I have NFI, but I'd guess you're missing a parenthesis in the first line........but then again....I have NFI. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Get your broken off allen wrench out? |
Lo-Fi Version | Time is now: 25th June 2024 - 10:33 PM |
