johnmhudson111 |
Member ![]() ![]() Group: Members Posts: 491 Joined: 29-November 04 From: Nesbit, MS Member No.: 3,191 ![]() |
So I am wacking away on the pickle fork seperating the 914 strut from the a arm and I notice I have effectivly destroyed the ball joints rubber cover and grease (I assume) is everywhere. I am thinking, this isn't good. No problem I got another set on the 911 a-arms, happy times again, but wait a second it turns out there is a special tool that you have to have to unscrew the nut on the bottom of the ball joint. Pelican has them for around $50. So that leads me to my two questions:
1. is there another way to remove the ball joint nut? if not is there a cheaper source? 2. is it unwise to use a used ball joint? Don't mind buying new but hey if you ain't got to.... (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
johnmhudson111 |
Ok, well I ponyed up for the P210 tool. I am going to give the ball joints on the 911 a arms I have a look to see if I can use them, if not you want to trade a couple of ball joints for a pair of /4 rear capliers? |
Lo-Fi Version | Time is now: 26th June 2024 - 09:18 AM |
