> Had a a massive flat spot, more like a bog
michel richard
post Aug 17 2005, 03:46 PM
I have indicated elsewhere that I used to run Mechanical Injection on the 2.2E engine in my 914. I switched to PMO carburetors because I had a huge flat spot, actually more like a through, a bog, an abyss, a souse hole, or a black hole, between 3,000 and 3,800 rpm, especially at WOT.
When the PMOs went on, I still had the bog, so I was massively disapointed.
Early this afternoon I made arrangements with my main mechanic man, and we went for a test drive. Sure enough, the abyss was still there. He felt that it was probably ignition related.
Back at the shop, he started fidling with a strobe light and reving the engine and figured out that the ignition was snapping to 72 degress advance between 3,600 and 3,800 rpm ! His immediate thought was that MSD box was causing the problem.
I drove back home and wired in a Bosch CDI unit that I got as part of my Jon Lowe project purchase . . . and that solved the problem. Final diagnostic: bad MSD box.
Moral of the story is: a lot of things that can look induction related to the amateur mechanic, are actually ignition. Make triple sure your ignition is 100% up to snuff before you start making big injection or carb changes.
Hope this experience can benefit others.
Michel Richard
michel richard   Had a a massive flat spot   Aug 17 2005, 03:46 PM
ArtechnikA   1) yet another reason to hate MSD. i know a lot o...   Aug 17 2005, 03:50 PM
michel richard     Aug 17 2005, 05:23 PM
michel richard   Hihi   Aug 17 2005, 05:28 PM
- Lo-Fi Version Time is now: 8th January 2025 - 03:03 PM
