MattR |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California ![]() |
Question for the type 4 masters out there:
My new 2056 is leaky (~1 qt in 10 mins from the oil cooler seals). I thought it was the seals, so I took those out and tried to seat them properly dozens of times with no luck. Now Im thinking its an oil pressure thing. I plug in my electrical VDO gauge and it pegs it (past 80 psi). I dont THINK my oil pressure relief pistons are stuck. I pulled the plugs and they slid freely in their bores. Are there any other suggestions for too much oil pressure? Im running a shadeck 30mm t1 pump and ive drilled and tapped all my oil galley plugs and cleaned the galleys. Ideas? |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
point of reference: i have a similar high flow pump... cold oil PSI at idle is about the same....but my cooler seals dont leak (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
and i have non stuck replacement bleed off pistons.... AA |
Lo-Fi Version | Time is now: 25th June 2024 - 08:37 PM |
