Clutch Tube reweld???, AA says to do it.... |
tracks914 |
Aug 18 2005, 02:59 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I find that I have to keep tightening my clutch every couple of weeks. In an AA catalogue, one of their little window box tips says that if this happens then you need to reweld your clutch tube.
Is this true? Where is the clutch tube located? tx |
tracks914 |
Aug 18 2005, 08:12 PM
Has anyone tried a small "U" bolt? It would be stronger than a spot weld, cleaner and the only down side I could see would be if you tightened it too much you could crush the tube. If you were able to drill out the old bracket over the tube and were able to put the "U" bolt through that, I would think it would be the strongest option.
The only down side I can see would be the nuts sticking out the side under the carpet. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 03:43 AM |
