rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,117 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
GOOD THING I HAVE PLENTY OF THESE.
K Attached image(s) ![]() |
rhodyguy |
i thought i had told you in a pm. so, what will happen is.... after the 2.0 is in the 75', i'll being doing this to the onion. pulling off the tin, pulling and inspecting the heads, determining the cr, inspecting the cyl as best i can, checking valve train geometry, checking the endplay, seeing if i can "read the cam", renewing the main seals, renewing the p.r. tube seals, plugging the missing air injecting plugs/bolts, replacing the f-ed up flywheel, replacing missing/f-ed up engine tin. while i'm in there might as well inspect the lifters. might just be easier to rebuild the whole thing. or drain the oil and give to al blose for a new boat anchor. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) so much for a "put on your carbs and install in your car" engine. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) blow me stromberg.
k |
Lo-Fi Version | Time is now: 28th June 2024 - 06:59 PM |
