echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
I have had a progressively worsening problem with part-full load bucking it seems to be worse when the engine is cold.
I have tested/replaced the TPS. Now I am leaning on the FI points being the culprit. How are these tested? What should I look for upon visual inspection? Any other causes for my symptoms? here is what I have gone through trying to nail this down: Ingition improperly set (mine is spot on to factory specs) Possible malfunctioning vac adv (mine seems to function with suction) Fuel pump/filter clog (my tank was recently acid bathed and has a new filter and a inline pressure gauge reads normal at idle and revs while sitting). |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
Could be lean surge from a bad temp sensor (CHT or IAT).
Lo-Fi Version | Time is now: 20th June 2024 - 09:11 AM |
