Undercoating Questions, Ziebart/Rusty Jones, etc |
turtleman |
Aug 26 2005, 04:44 PM
Member Group: Members Posts: 74 Joined: 1-June 05 From: New England Member No.: 4,183 |
Those of you who have done complete restorations might be best able to answer some of my questions.
I was wondering if anyone had experience removing a Ziebart undercoating from a car and how much rust was present under that coating? My floorpan appears very solid and rust free, however, I am aware that on occasions moisture can form between poorly bonded rustproofing and there can be much rust under the undercoating. I assume that cars that were rustproofed at the dealer when they were new might have had a better chance of having betterbonding of their undercoating than cars where the undercoating was applied at a later date when dirt and grease might have made the bonding poor. I am interested in knowing if anyone had a car that had Ziebart rustproofing that turned out to be relatively free of rust when they removed the undercoating? Also out of curiosity, I wondered about anyone who had a Rusty Jones undercoating how their car looked after removing the undercoating? I sure would hate to remove all my uindercoating if it is actuially working and still effective, which appears it is. I appreaciate any discussion on this topic. Chip |
McMark |
Aug 26 2005, 05:07 PM
This is an indirect answer to your question.
I think that a greater rust issue for these cars is the fender sealing foam, not the undercoating. The sealer that was sprayed up in the corners of the fender wells (rear door jamb/sail panel area & rear tail light area especially) is causing most of the problems I'm seeing. Before I would recommend any spend time dealing with undercoating I would make them deal with this foam/sealer. But more appropriately to your question, I don't think undercoating is a real big problem. If I had a car that I was worried about insufficient undercoating bond, I would take it to a coin-op car wash, put it up on jack stands and remove the wheels and spray it with the pressure sprayer. Anything that's loose will fly away, and anything else will just get clean. So it's a win-win situation. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Lo-Fi Version | Time is now: 28th June 2024 - 10:57 PM |
