> front mounted cooler - oil lines, what material?
Bob Wolcott
post Aug 27 2005, 08:37 PM
I have the shroud finished and I now need to route the oil lines back to the engine compartment. What material are the hard lines made of? Here are a few pictures of the lines in question.
http://www.pbase.com/9146gt/image/44622264
http://www.pbase.com/9146gt/image/44622265
Where can these lines be found, or do they have to be fabricated? Is there an easier way like running braided line instead of hard lines?
Thanks,
Bob
Bob Wolcott
post Aug 27 2005, 11:29 PM
I was thinking that the solder melting point was ~450 degrees or so and if the oil was running at 200 that would be a close margin considering heat cycling and fatigue. If the stuff melts at 700 degrees there shouldn't be any problem. Where could I find the dimensions (technical drawing) for the 12-AN fitting?
Thanks,
Bob
Bob Wolcott   front mounted cooler - oil lines   Aug 27 2005, 08:37 PM
sixnotfour   Those lines are the factory GT lines , they are br...   Aug 27 2005, 09:26 PM
trekkor   I think those are copper. I'm very interested...   Aug 27 2005, 10:13 PM
Bob Wolcott   I would be able to machine brass ends to use with ...   Aug 27 2005, 10:17 PM
sixnotfour     Aug 27 2005, 10:38 PM
trekkor   You can "sweat" them on just like home water plumb...   Aug 27 2005, 10:39 PM
Jeroen   IIRC there've been a couple of threads on the ...   Aug 28 2005, 02:25 PM
davec   I have used -12 and -16 steel braided with excelle...   Aug 28 2005, 06:40 PM
- Lo-Fi Version Time is now: 13th January 2025 - 11:39 PM
