lost low beams, lows down work, highs do |
mikelsr |
Aug 29 2005, 08:00 AM
Senior Member Group: Members Posts: 657 Joined: 2-January 05 From: Mahomet, IL Member No.: 3,390 Region Association: Southwest Region |
I went to take the teener for a night drive and found that I don't have the low beams anymore. The high beams work fine. The only thing I did was to pull out the old antenna lead and put a new one in. I am looking for single point of failures since both lights don't work. One is the fuse (hich is good), second is ground (need to find and check that), and third is a relay (can someone point me to the correct relay). Any other thing I should be looking at?
TIA |
lapuwali |
Aug 29 2005, 08:31 AM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
There are two fuses (right and left low beams), and two ground points. There's no relay, unless a PO has added one. There may be only one wire leading in to your fuses (the fuses are bussed together in the fusebox). Fuses 3&4, the large yellow wires, counted left to right. Check to see if the yellow wire from the switch is plugged in, and then check to see if you have power with the headlight switch pulled completely out. If you don't, start looking at the switch itself.
Lo-Fi Version | Time is now: 21st September 2024 - 07:12 PM |
