Removing an Axle with a broken CV, How do you keep it from turning |
Jaiden |
Aug 30 2005, 09:21 AM
Member Group: Members Posts: 346 Joined: 13-January 05 From: Stroudsburg PA Member No.: 3,443 |
So I'm about to start the tear down of the rear end to swap out the axle that has a blown CV joint.
But the issue I will have is how do I keep the axle from turning while I try to loosen the Axle bolt's out of the Transmission? Any Tips? I really want to make it to the ECC so I have to get this swap done as quickly as possible. Thanks in Advance. |
JWest |
Aug 30 2005, 09:38 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Nope, the spider gears in the differential will rotate and the flange will still spin. Try a strap wrench on the body of the CV. |
Lo-Fi Version | Time is now: 30th June 2024 - 10:49 PM |
