Removing an Axle with a broken CV, How do you keep it from turning |
Jaiden |
Aug 30 2005, 09:21 AM
Member Group: Members Posts: 346 Joined: 13-January 05 From: Stroudsburg PA Member No.: 3,443 |
So I'm about to start the tear down of the rear end to swap out the axle that has a blown CV joint.
But the issue I will have is how do I keep the axle from turning while I try to loosen the Axle bolt's out of the Transmission? Any Tips? I really want to make it to the ECC so I have to get this swap done as quickly as possible. Thanks in Advance. |
Demick |
Aug 30 2005, 07:21 PM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
BTW. I use an air ratchet to remove the CV bolts. Takes them right out. But I don't think I would use any power tools unless you have had the bolts out within the last 2 or 3 years. If you've never had them out before, you don't know how hard they might be stuck - and there is no better way to strip the head than to use a power tool.
Demick |
Lo-Fi Version | Time is now: 28th June 2024 - 07:09 PM |
