> Starter Booster, I hate to revisit this topic, but...
black914
post Sep 4 2005, 03:11 PM
I have found this topic through a search but my question remains unanswered! I went down to the Queen City yesterday to do a repair on my son's 924S. The trip is essentially 85 miles of 65 miles per hour non-stop driving. When I arrived and rested for about thrity minutes, we decided to go get something to eat first, got in the 914, turned the ignition switch and no turnover. The fuel pump was operating but the starter was not getting the signal. I let it cool for a while, attempted to crank it again and it fired right away. We ran a few errands and made about three stops requiring the engine to be turned off and restarted and I encountered no problems. Went home later in the day around 6:30PM, traveled the miles at 65 steady for about one hour, stopped to get a cola, got back in, attempted to crank it, but again, nothing. Fortunately a good samaritan help me push it off and I got it cranked okay. I got home safely.
I notice that Bosch has encountered this problem before and they have offered a starter booster kit that cures the hot starter problem by boosting the voltage to the starter. My 914 has a remanufactured starter (don't know the age because it was installed by the previous owner).
Would this cure my problem? Apparently it has been a problem in the past or Bosch would not have offered a cure.
Comments?
black914
post Sep 4 2005, 06:31 PM
Travis,
Battery ground and transmission ground are brand new. I'll investigate the starter wire tomorrow. I just hate to replace the solenoid if it is not the culprit. I suspect heat is the main issue here because the car seems to start fine when it is cool.
black914   Starter Booster   Sep 4 2005, 03:11 PM
Travis Neff   the starter booster is nothing more than a band ai...   Sep 4 2005, 03:36 PM
rhodyguy   or spend $90 and forget about it. you'll ...   Sep 4 2005, 03:47 PM
black914   So....... This returns to my original question. I...   Sep 4 2005, 04:08 PM
SLITS   Heat increases resistance in the wires and commens...   Sep 4 2005, 04:21 PM
Travis Neff   Forgot about the switch. There is about 20ft of w...   Sep 4 2005, 06:24 PM
black914   Travis, Battery ground and transmission ground ar...   Sep 4 2005, 06:31 PM
914GT   I had the 'hot start' problem soon after I...   Sep 4 2005, 07:01 PM
jasons   I just think the relay makes sense. Even if you h...   Sep 4 2005, 09:16 PM
trekkor     Sep 4 2005, 09:16 PM
smooth_eddy   I too have a hot start problem. I did searches an...   Sep 4 2005, 09:39 PM
Mark Henry     Sep 5 2005, 09:06 AM
Spoke   http://www.914world....   Sep 18 2005, 02:38 PM
DJsRepS   Just fix it right dont use any FORD parts at all, ...   Sep 18 2005, 06:10 PM
Tobra   and then you get Found On Road Dead. My car has t...   Sep 18 2005, 09:10 PM
jsteele22   Okay, so this thread is a little old, but maybe a ...   Oct 10 2005, 03:12 PM
jsteele22   Actually, I've been searching even deeper into...   Oct 10 2005, 03:57 PM
914GT   You really don't need the 'Ford relay...   Oct 10 2005, 04:02 PM
bulitt   You really don't need the 'Ford relay...   Oct 3 2012, 04:07 AM
DJsRepS   I dont see why any one needs any realy the germans...   Oct 10 2005, 04:18 PM
brant   I've had cars with the ford relay still not st...   Oct 10 2005, 04:23 PM
jsteele22   So my car already came with a relay and is having ...   Oct 10 2005, 05:08 PM
914GT   I don't know about the hammer idea, but I know...   Oct 10 2005, 05:31 PM
Mark Henry   Most late fords didn't have a soleniod on the ...   Oct 10 2005, 06:11 PM
ClayPerrine   I had this problem on Betty's car for years. P...   Oct 10 2005, 07:10 PM
brant     Oct 13 2005, 05:56 AM
brant     Oct 13 2005, 04:35 PM
jasons     Oct 13 2005, 05:47 PM
914GT     Oct 13 2005, 06:26 PM
Mark Henry     Oct 14 2005, 04:48 AM
SLITS   If you have ever taken an automotive solenoid apar...   Oct 2 2012, 10:34 PM
- Lo-Fi Version Time is now: 8th January 2025 - 03:49 PM
