Anton |
Royal Orange ![]() ![]() Group: Members Posts: 161 Joined: 25-March 03 From: The Netherlands Member No.: 473 ![]() |
My 1.8 engine was running badly at idle and sounded harsh on acceleration. CO screw and dwell/ignition tune-up did not solve the problem. I thought it was time for another valve job until a 914 buddy of mine, Richard, adviced me to check on the airflow sensor. (IMG:style_emoticons/default/ohmy.gif)
After removing mucho messy glue on the cover (thanks, PO) and opening of the sensor, I found that the mixture was way too lean. There was a marking of the old position that was richer, but only after adjusting beyond this point, at a total of 8 (!) teeth on the wheel, idle became regular. What it did to acceleration and low rev. driving was even more remarkable... Is this what a 914 can do...? (IMG:style_emoticons/default/laugh.gif) It all became evident after a period of driving with backfire due to wrong dwell/timing. Some of you will now probably say "evidently". Also I have heard of this problem before, "just readjust a couple of teeth on the wheel", but a total of 8 teeth! (IMG:style_emoticons/default/blink.gif) Anybody care to comment on this? Is this usual for an L-jet? BTW, I have not yet checked the current CO reading. |
MartyYeoman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California ![]() ![]() |
I have a '75 1.8 with 2.0 pistons. I have had to adjust my air box by 6 teeth. You also have to adjust the small arm on the rotation plate to properly restore idle after spring softening (tooth repositioning). I keep two air boxes around. One for everyday use and one for biannual smog check. 8 teeth really doesn't sound to out of the ordinary.
Marty |
Lo-Fi Version | Time is now: 27th June 2024 - 07:58 PM |
