Petrol Pump Polarity, Quick confirmation please! |
aveale |
Sep 8 2005, 07:13 AM
Fun Times Group: Members Posts: 194 Joined: 18-August 04 From: Ottawa, Canada Member No.: 2,563 |
Can anyone confirm that the fuel pump, when the wires are reversed (i.e. pos instead of negative) WILL NOT RUN?
I just dont want to run the bugger in reverse (fuel pump, not car). T |
Cap'n Krusty |
Sep 8 2005, 09:07 AM
Brown is ground in German cars. IF yours is unmolested, the brown wire should be ground. The stock wiring for the 70-74 cars has a plug which fits into the socket on the pump, preventing you from screwing up. Late cars have 2 loose wires. You might go the extra mile and actually test the wiring with a test light. Remember, the 12v + wire to the pump is energized for only 1.5 seconds when you turn the key on, then it goes dead until the car is cranked or you recycle the ignition switch. The ground wire stays ground all the time. The Cap'n
Lo-Fi Version | Time is now: 6th January 2025 - 04:27 PM |
