EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
These are the two gauges that came out of my 914 that I'd like to go back in with the stock volt meter. The VDO oil temp gauge should work with the sender that's already in the car. I don't remember if the oil pressure gauge works. I took the sender pictured - off the HPH engine except for the tube on top of the engine it was attached to (just spins). Do I need some more parts to make it work? Would Rich have what I need? (Did I really ask that?)
I've got a tech function tomorrow night so I might miss you if you're nearby until about 9. The tool guy across the street would like to talk if you're still interested though. Let me know if I can arrange something. Attached image(s) ![]() |
EdwardBlume |
I pulled the sender from the Botempi motor that was matched to this gauge and put it in so it should be OK.
Yeah I was lazy on the picts. How do I reduce the size? What part do I need again? |
Lo-Fi Version | Time is now: 24th June 2024 - 11:32 PM |
