wilchek |
Senior Member ![]() ![]() ![]() Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 ![]() |
has anyone created and easy diagram for wiring the engine out of the car. I know it is not that hard, but wiring is not my stongest asset and I would rather not fry the computer on my 73 2.0 system. Would it be easier with a relay board. BTW bone stock 73 2.0, yes the mps holds pressure, well at least now. How much should i expect the engine to move when bolted with the mounting bar to a wood cart I made.
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
Use the relay board and the engine side wiring harness. You don't need the alternator bit. You'll need a pair of switches in the 20 amp range, one for power, one for the starter.
Plug in everything to relay board as it should be, except the 14 pin plug. All you'll need to get the engine going are the red wires (battery +), the brown wires (to battery -), the black wire (to your power switch, the other end of the power switch should connect to battery +), the yellow wire (to your starter switch, the other end of the starter to battery +). The ECU needs to be plugged in, including the connection to the relay board. You'll be powering the ignition right off the battery, so you'll need a charged battery and you can't run it for long (20 minutes or so). Use 14 gauge wire everywhere. |
Lo-Fi Version | Time is now: 25th June 2024 - 11:56 PM |
