billd |
Member ![]() ![]() Group: Members Posts: 327 Joined: 25-May 05 From: Palo Alto, CA Member No.: 4,145 ![]() |
I started out to restore my 73 2.0L to its original D-Jetronic fuel injection. At some point I decided that I while I was working on the fuel system I might as well replace the plastic lines with stainless steel and relocate the pump. Here are some pictures with commentary of the fuel line upgrade.
Overall the fuel line install was fairly easy. It would have been much easier if I hadn't decided to run one solid line from the tank all the way to by the MPS sensor. If I did this over again I would do everything the same except that the solid lines would stop at the right side of the firewall and I'd run hose from there. First, I removed the interior and pulled the fuel tank. Here is a photo of the tank halfway out. The hoses on the tank were long enough that I didn't need to disconnect them through the service hole below the tank. I was able to lift the tank to this position and then disconnect the hoses from above. The new hoses I installed are also long enough to permit access from above. Attached thumbnail(s) ![]() |
jsteele22 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 ![]() |
Great job, thanks for the post. I have a couple of questions.
1) Just to be sure : Did you do the whole job w/ the engine in the car ? 2) When you are pushing the lines in from the rear, how do you manage to get them to come out at the front end of the tunnel ? I haven't done any work in that area, but it sounds like a tough job : like threading a needle from a foot away. 3) What do you use to cut the tubing ? Would a regular (home plumbing style) tubing cutter do the job ? I'm guessing this stuff is too hard for that. 4) Did you use a special beding tool, or just do it by hand ? Thx, Jeff |
Lo-Fi Version | Time is now: 30th June 2024 - 06:18 PM |
