nebreitling |
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 ![]() |
hi all
i've discovered a weird ignition/fuel system quirk in my '75 2.0, which has probably been going on since i've owned it (3 months) -- just haven't noticed it. the engine has a flatspot at ~4600rpm -- it feels like the fuel cuts in and out to keep the engine below this speed. now, i can 'break through' it in 1st --> 3rd gear, it just pauses and stumbles a bit at 4600, then moves merrily along toward redline. but in 4th (and 5th, i presume), it feels like i don't have enough power/momentum to 'break through it'. 2 months ago, car had a full tune up, valves adjusted, etc. airpump removed, air injector jets plugged. aside from this quirk, it runs smoothly and strong. does anyone have suggestions for things to check? (IMG:style_emoticons/default/confused24.gif) nathan |
nebreitling |
QUOTE(RustyWa @ Aug 7 2003, 05:20 PM) For testing, I've heard you can disconnect the TPS and see if that cures your problem. TPS = ? TemPerature Sensor? if so, did you replace the Cylinder Head Temperature Sensor (Temp Sensor II) or the Temperature Sensor I? or perhaps it's the Throttle Switch? (i'm thinking Throttle Position Switch, TPS?) if so, $85 is a good deal (IMG:style_emoticons/default/clap56.gif) thanks, gentlemen |
Lo-Fi Version | Time is now: 4th July 2024 - 01:39 PM |
