Handling |
Handling |
-P- |
Aug 7 2003, 03:28 PM
P-Factor Group: Members Posts: 207 Joined: 1-July 03 From: Dallas, TX Member No.: 873 |
I'm ready to dive into improving the handling of my car. I will be 90% street driven, but by no means a daily driver so I dont care about ride quality. It's all about performance
Here is what I have planned so far:
Brad Roberts |
Aug 7 2003, 11:24 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
QUOTE cavwpguy, Sorry to disagree but you are the first person ever to say run a rear bar and the front bar is a toss up. Your car must oversteer like crazy. Mine did when I ran front and a rear bars and I took the rear bar out. And now I can't give the thing away. You will quickly find that your 19mm is maxed out when you really start to drive the car. I ONLY recommend the 22 now. Its a waste of time buy the 19mm and end up with it set on full stiff 6 months after learning the car. Buy the 22mm and set it in the middle to start off. It will give you room to "adjust". Paul, I have been driving CaVW's car for 4-5 days now... it is ROCK solid with this setup (I installed it).. I'm going with larger sway bars in the front to compensate for lack of torsion bars (CaVW has stock bars) Once we install a larger torsion bars.. my adjustability range changes... so start off with a larger bar (more range of adjustment) We really like the cars to be a little softer sprung and run a big front bar and a rear bar. You wont see Rob's car lifting a tire..ever. B |
Lo-Fi Version | Time is now: 27th June 2024 - 11:36 PM |
