Hydraulic Floor Jack......., No workie |
smooth_eddy |
Sep 30 2005, 04:40 PM
Senior Member Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 |
I was just given this floor jack. Mechanically it looks fine, but it does not jack. I closed the valve and pumped the handle. It moves an inch or so. When I release the handle it goes down. I am thinking hydraulic fluid? So where is the reservoir located? I tried the little screw, but the hole is too small. It this a bleeder hole? Next thought was to remove the nut above the ram. Unfortunately there is an E clip above the spring and I can't remove it. I am sure there is a special tool right? If it works it would be a nice score for the $3 bucks it cost for the hydraulic fluid. Thanks, Eddy
Attached image(s) |
SLITS |
Sep 30 2005, 04:45 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
stand jack upright, pull the screw plug in the pic and fill it with hydraulic fluid (it doesn't take a large hole for hydraulic fluid)....if not that then it is the "0" rings on the piston.
Lo-Fi Version | Time is now: 6th January 2025 - 07:26 PM |
