shaggy |
mechanic/welder/fabricator ![]() ![]() ![]() Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None ![]() |
i have a crazy ass question...
can i put in a larger fuel tank? what about if i took out my one (bled it for sure!) then torched the side that faces forward and got another 914 tank did they same thing to it then welded them pack together made sure they were sealed and pressure tested it and put it back in? would the fuel pump handle all that? would i need to change me front suspension? ...or does this sound like an all together bad idea? |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
You could do it. You wouldn't have to fill up as much, but you'll add a ton of weight in extra metal and extra gas. Gas ain't light. Since you want to go faster you should forget about adding that much weight.
Lo-Fi Version | Time is now: 25th June 2024 - 08:21 PM |
