> what the hell happened?, i have no idea whats going on
shaggy
post Oct 2 2005, 02:34 AM
mechanic/welder/fabricator
i was exiting a neighbor hood and it was grinding as i was down shifting into 2nd and as i was putting it into first, but not as i shifted up into 2nd. i knew something was wrong but i was in no position to stop and push the car home or anything like that. so i keep driving, carefully.
so i was coming home on the freeway, its about 12:45 am, and i was having trouble shifting into 4th it was kinda like blocked almost. so i drive more on the freeway and the clutch is actin all weird. the last i remember is the clutch was like halfway depressed without my foot being on it. so i didnt know what was going on so i hit the clutch and it did nothing, dropped it to the floor and nothing happened, didnt drop out of gear im sure cuz i had my foot on the accelerator and i could hear it in gear and the revs didnt shoot up like they should have. after i depressed the clutch about...maybe 3 times...it sticks to the floor. dosent pop back up and its still stuck in 5th! so im thinkin 'OH SHIT. ITS STUCK IN FIFTH AND I HAVE TO EXIT THE FREEWAY AND GO THROUGH MY NEIGHBOR HOOD TO GET HOME.' so i exit the freeway as slowly as i can in 5th. i drop it to about 700 rpm just enough to keep it from stalling. then i have to make a hard 90. so i make it again as slow i can w/o stalling. then im close enough that i can kill the engine and drift so i do and now that i have the key out and on the dash i drift in and as i do i hear what sounds like things coming apart... (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)...so i park it and jump out and lay on my back under the car (as much as i can). i see my tranny its kinda covered in oil lookin. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
i dont know what going on. we have two trannys in out garage and it looks like im gonna lean to rebuild them now...
what should i do about the clutch thing?
can i replace a clutch myself?
what did i do wrong and how can i fix it?
what should i do?
id like to do all the work myself to keep the cost down...if i can... (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
any help, advice, or sympathy would be appriciated...
ArtechnikA
post Oct 2 2005, 07:21 AM
rich herzog
my guess is your engine or transmission mounts (or both) have disintegated and your driveline is sitting on the shift rod. that would be in addition to whatever's going on with the clutch.
engine or transmission oil? makes a difference so you'll know which seal failed and soaked your clutch with what kind of oil.
you know how to shift without a clutch, yes ? god thing to know.
for future reference: NEVER PULL THE KEY UNTIL THE CAR IS STOPPED! on lots of cars, the steering lock won't engage with the key in the ignition. just switch off. having the steering locked in a moving car is A Bad Thing.
welcome to the world of vintage sports cars. get a cell phone and AAA.
good luck.
shaggy   what the hell happened?   Oct 2 2005, 02:34 AM
MecGen   Ok Dude Sounds like a strait ass clutch problem, ...   Oct 2 2005, 02:56 AM
michelko   Maybe clutch tube broke through firewall? Check th...   Oct 2 2005, 02:59 AM
ArtechnikA   my guess is your engine or transmission mounts (or...   Oct 2 2005, 07:21 AM
Dave_Darling   The clutch pedal went to the floor? One of two th...   Oct 2 2005, 09:36 AM
cooltimes   Clutch cable wrapped around a gizmo in the cable l...   Oct 2 2005, 09:49 AM
Andyrew   I agree totally with dave. If it was an imediate B...   Oct 2 2005, 11:13 AM
Dave_Darling     Oct 2 2005, 01:10 PM
Hammy
- Lo-Fi Version Time is now: 27th December 2024 - 09:38 AM
