vesnyder |
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 ![]() |
Trying to figure out why my fuel pump is not getting any power and determined the power for the pump comes directly off the coil. The voltage leaving the relay panel is ~12V, but coming into the coil is only about 2-3V - that is with the wire disconnected - with it connected to the coil it is only ~.3V. Is this right? How do I determine if the coil is bad? How much for a new one?
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(vesnyder @ Oct 3 2005, 09:23 AM) the power for the pump comes directly off the coil. time to rewire. someone HACKED your setup ... do not run power for the fuel-pump off the coil! now, even if your car is converted to carbs, simply use the stock FI-Pump leads to run your fuel pump. i wrote a little blob on how to do that, which you can find in the "Classic Message Threads" section. right here: http://www.914world.com/bbs2/index.php?act=...=ST&f=5&t=25954 (IMG:style_emoticons/default/wink.gif) Andy |
Lo-Fi Version | Time is now: 26th June 2024 - 09:32 AM |
