Electrical Guys Help - No Power to Fuel Pump, Could it be a bad coil? |
vesnyder |
Oct 3 2005, 10:23 AM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
Trying to figure out why my fuel pump is not getting any power and determined the power for the pump comes directly off the coil. The voltage leaving the relay panel is ~12V, but coming into the coil is only about 2-3V - that is with the wire disconnected - with it connected to the coil it is only ~.3V. Is this right? How do I determine if the coil is bad? How much for a new one?
SirAndy |
Oct 3 2005, 02:08 PM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(vesnyder @ Oct 3 2005, 12:52 PM) This does not emilinate the relay or the fuse from the circuit? we all already passed you and left you in the dust ... (IMG:style_emoticons/default/biggrin.gif) from your original post it sounded like you had a carb-converted car and someone had run a hot wire *directly* from the coil to the pump. now that we know you got D-Jet, that has been eliminated, but we're still debating on how "safe" that really is, running the pump *straight* off the coil. in case you haven't noticed, this was/is a (IMG:style_emoticons/default/hijacked.gif) (IMG:style_emoticons/default/rolleyes.gif) Andy |
Lo-Fi Version | Time is now: 26th June 2024 - 09:28 AM |
