vesnyder |
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 ![]() |
Trying to figure out why my fuel pump is not getting any power and determined the power for the pump comes directly off the coil. The voltage leaving the relay panel is ~12V, but coming into the coil is only about 2-3V - that is with the wire disconnected - with it connected to the coil it is only ~.3V. Is this right? How do I determine if the coil is bad? How much for a new one?
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
I didn't say, or mean to suggest, it was good practice to run the fuel pump off the coil, only that it's commonly done.
Just trying to help solve this one problem, not re-engineer the wiring completely. My mistake on the coil not being powered by the relay in stock form. I assumed the 25A fuse and the associated relay on the relay board ran the coil. Back to the original topic... Is there a dedicated wire on your car from the coil + terminal directly to the fuel pump? If not, then we need to back up and find out exactly what your problem actually is. If so, then someone has hacked up your wiring, and all bets are off on what *should* happen v. what's actually happening on your car. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:25 AM |
