dbledsoe |
Mutineer ![]() ![]() Group: Members Posts: 300 Joined: 13-May 03 From: Boise, ID. Member No.: 687 ![]() |
I'm nearing the final stages of a Buick V6 swap into my 914. I am using an MSD billet distributor and MSD 6200A ignition box. As best I can tell from the Haines wiring diagram, the 914 12 pin harness wire, black wire with purple stripe that normally connects to the negative side of the coil, is the tach signal wire. I am guessing (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) that the black/purple wire would be the one to connect to the MSD box tach output signal connection. Can anyone correct me on this if I am wrong in my guess? (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
Thanks, Don |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
Here's the thread:
Tach mods I'm not convinced there's a 100% correlation between the finish on the center button and the tach input circuitry. Did the '74 tachs also have a single turn signal light and the high-beam light at the top rather than the bottom of the face? |
Lo-Fi Version | Time is now: 26th June 2024 - 12:32 PM |
