Eddie914 |
Unregistered ![]() |
What are the odds of removing all the exhaust studs from a 1977 Porsche 2.7L six cylinder engine without breaking any? I'm planning on applying heat from a MAP gas torch to the cylinder head area adjacent to the stud. What is the best technique? The threads were given liberal application of PB Blaster penetrating oil 4 days ago.
The engine currently has what appear to be 10 original necked studs and two replacement studs with constant thickness. Bursch headers will be used which thinner flanges than the original heat exchangers. Thanks Eddie |
spare time toys |
hooked on grilling food. ![]() ![]() ![]() ![]() Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region ![]() |
Hot tip no pun intended. On my 928 heads I had a bunch of stuck studs. When you have the head nice and toasty put paraphin wax where the stud goes into the head. It will wick down in along the threads and they will come right out. I had no trouble with any of mine doing this other than the one that is broken off down in the head. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
Lo-Fi Version | Time is now: 26th June 2024 - 06:22 AM |
