cantley914 |
Pipeline surgeon ![]() ![]() Group: Members Posts: 306 Joined: 15-June 04 From: Cantley, Qc Canada Member No.: 2,210 ![]() |
I would like to know the torque requirement for the three bolts on the front stabilizer bar triangular plate to body.
(IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) Steph |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
...how to put a meaningful title on a thread? maybe not. no published specs i could find for antiroll bar mounts, but the "standard" for a grade 8,8 8mm fastener is around 2,5 m/Kg - or 18 lbs-ft. if the fastenrs are going into a captive-nut plate, you could safety-wire them after torquing and then you'd know they were tight by looking, but they're not really subject to any kind of loosening stresses, and you'd check them with a socket as part of your pre-track nut-and-bolt chack anyway. 15-20 lbs-ft which most of us here describe as "very snug" to "tight". |
Lo-Fi Version | Time is now: 26th June 2024 - 08:26 AM |
