SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
ok, i'd like to get an educated guess as to what my approx. max. RPM would be with a 2056 with heavy duty dual valve springs, solid rocker spacers, 911 swivels, slightly bigger valves, 9:1 compression ...
as far as i can tell, the components used are good quality. i had the rev. limiter set to 6000 rpm which seemed to be on the safe side. only hit the limiter 2 or 3 times during a AX. always ran plenty of oil, got a tuna can on the motor. no lean running ... the motor always felt like it wanted to pull past 6000 and wasn't done with it's peak power yet so i'm thinking there has to be more ... anyone who can give me a hint as to where the redline could be? ballpark? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Andy |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
I bet you didn't have a CHT gauge....
BUY FRIGGIN GAUGES!!!!!!!!!!! Heads don't crack without getting overheated! Andy, sounds like it's time to do some trading- you know what I need. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:11 PM |
